Turn off pc electrical noise?
Last response: in Components
- SolvedPower socket made a buzzing electrical noise when I turn on the Power supply unit Forum
- SolvedPC made a popping noise, turns off randomly and is very hot! Forum
- Pc makes popping noise turns off then restarts. Forum
- PSU makes little whistle noise when PC is turned off Forum
- Solvedwhen I turn off my computer theres a high pitch but faint noise Forum
- I Have a Gateway PC and when it loads up Windows vista it makes 3 beeping noises and turns off Forum
- My new Cosair RM850 is making a click noise every time i turn it on or off Forum
- SolvedHow do I turn this noise off ? Forum
- PC doesn't Turn On. some electrical sound Forum
- My RCA HDTV model # D56W20 makes a screeching noise then turns off a coup[le of seconds after i turn it on. Forum
- SolvedPC randomly shuts off and wont turn back on until PSU replugged Forum
- SolvedPC made loud noise and give off burning smell during bootup Forum
- [Hero 5th] Turning On/Off Electrical Appliances/Devices Forum
- SolvedEverything open on my computer, stops responding, task manager wont open, and my pc wont turn off unless I hold down the power Forum
- SolvedPC won`t turn on after power was cut off. Forum
- SolvedPc turned itself off and won't turn back on Forum
- SolvedWoke up computer was off, turned it on and PSU was making loud noise Forum
- Screeching noise coming from speakers when I turn off my computer? Forum
- SolvedPC won't boot unless I turn off the PSU and press the start button for 15-30 secs Forum
- Solvedpc wont turn off after a shutdown Forum
- More resources
Read discussions in other Components categories
