Solved
Will 1000w power 2 6970 cards?
Last response: in Components
September 3, 2011 2:29:11 AM
i havw asrock p67 extreme4 8gb ram 2500k. once i get the cards i will be watercooling and oc'ing cpu to like 4.5, somewhere in that area. will i have enough juice to power it all?
More about : 1000w power 6970 cards
a b ) Power supply
September 3, 2011 7:07:23 PM
The 6970 card draws about 227w / ~19 amps. on the 12v rail when under full load - but not overclocked.
http://www.techpowerup.com/articles/overclocking/159
The Coolermaster Silent Pro M (your link is incorrect), has 80 amps. available on the single 12v rail so it has plenty of power for even (3) 6970 Vid cards and the rest of your system.
Jonnyguru has a mixed opinion on this PSU.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
You can always determine the required PSU power for your system by inputting your hardware into the PSU calculator at the link below.
http://extreme.outervision.com/psucalculatorlite.jsp
m
l
September 4, 2011 7:19:01 AM
It can handle it.
You'd be better with a quality Seasonic/Corsair 850W unit.
m
l
September 4, 2011 12:46:18 PM
i already have the coolermaster one. so its no good then?
m
l
a c 87 ) Power supply
September 4, 2011 3:22:48 PM
The only thing 'wrong' with it is that it doesn't have the tightest voltage regulation. But it is still well inside the specification.
m
l
Best solution
a b ) Power supply
September 4, 2011 7:23:26 PM
If you want to go Nvidia, go for 2x GTX 570. MUCH BETTER power/performance/price efficient. Unless you have unlimited funds. :)
The GTX 580 is only about 10-15% stronger than the 570, while costing almost twice as much. GTX 580 is a rip off, and is there/priced to be the show-off card.
If you already have a CoolerMaster 1000w I'm sure you'll be fine. A quality 1000w continuous is a little overkill, but if you already have the CoolerMaster, you'll be fine.
September 5, 2011 4:44:01 AM
ok how future proof would 2 570s be? would they run games maxed for at least two years? and i currently have a msi 6970 twin frozr at factory settings, how would a 570 compare to it?
m
l
September 15, 2011 4:47:56 AM
Best answer selected by Tjosborne.
m
l
a b ) Power supply
September 15, 2011 8:55:09 AM
the 6970 beats the 570 on most fronts
m
l
September 15, 2011 9:17:02 AM
I agree Obsidian86. 570 is a mess. 6970 would be much better and have great improvement.
m
l
