Sign-in / Sign-up
$400-500 World of Warcraft build(retaining some parts)
  • Build
  • World Of Warcraft
  • Systems
  • Product
Last response: in Systems
June 8, 2011 5:32:45 PM
Hello,
I wanted to see if anyone can help me with making a semi-new build so that I can run World of Warcraft smooth as a babys bottom. I plan on retaining my Hard drives, power supply, case, monitor(for now),and possibly my gfx card.
What I'm looking for help with is a good bang for my buck configuration for pretty much only a Mobo, CPU, memory, and possibly a gfx card combo for about $400-500 if possible. Any help is appreciated, thanks.
More about : 400 500 world warcraft build retaining parts
June 8, 2011 9:32:05 PM
While I don't know anything about world of warcraft specifically, I can tell you we'll need to know what power supply and graphics you have now to come up with a good recommendation.
m
l
June 9, 2011 8:28:08 AM
First off, what are the specs of what you are keeping?
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$30 Xigmatek ASGARD II
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$41 Antec VP-450 450W
MB: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$60 ASUS M4A78LT-M LE AM3 AMD 780L Micro ATX (hybrid X-Fire)
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$75 AMD Athlon II X3 445 Rana 3.1GHz Retail (WoW can use 3 cores, with a reg hack)
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$37 G.SKILL Value Series 4GB 240-Pin DDR3 SDRAM DDR3 1333 (if you get 64bit Win 7, get 2 of these)
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$40 Western Digital Caviar Blue WD3200AAKX 320GB 7200 RPM 16MB Cache SATA 6.0Gb/s
Vid: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
$100 XFX HD-667X-ZAF3 Radeon HD 6670 1GB 128-bit GDDR5
Total no OS: $383 + S&H (not counting combo/rebates)
m
l
