Closed Solved
Will cooler master hyper 212 evo fit in my motherboard ?
i wanna overclock my phenom 955 to 4 ghz planning to get coolermaster hyper 212 evo will it fit in my asus m3n78-em motherboard ? Also will it damage its vrm cause i have heard that this cooler reduces airflow to the vrm ??
14 answers Last reply Best Answer
More about will cooler master hyper motherboard
  1. Yes it will, no problem there : )
  2. Its more about the RAM. Do u have low profile?
    Like this one? No problem than.
  3. will it damage my vrm ??
  4. yep very low profile without heatsinks !!
  5. Best answer
    No, it will not damage anything : )
    It should be perfect fit!
  6. i was initially thinking about getting a new asus motherboard with amd 770 chipset and ddr3 is it a worthy upgrade from my current setup for only gaming ??
  7. Well it depends how much improvement would u want.
    Make no sense to spend money to get a little, because the final result will be disappointing, as it would not improve that much.
    Spend $400+ more and it would definitely be visible, that difference.
    DDR3 would not improve all that much. I would stay or invest in the IB+Z77
  8. But, if u like what u got, stay there : ))
    No need to spend more, because the will be always something faster.
  9. thanks for your quick reply :-) i will stay with this current setup will wait for amd piledriver :-) i know amd is inferior but i like underdogs :-)
  10. Best answer selected by brajesh143.
  11. Hey, whatever makes u happy, right?
    HW race will not stop.
    Not too long ago I got 2600K and now its surpassed by few others : )
  12. Cool! Good luck!
  13. This topic has been closed by Nikorr
Asus Cooler Master Motherboards Evo
