hi
i have i have a fujitsu siemens ms-7293vp and i wanna take intel core 2 duo e8400,or intel dual core e5700
here is my current cpu! from SISOFTWARE SANDRA(i have 2 cores) they are exactly the same
SiSoftware Sandra
Processor
Manufacturer : Intel
Model : Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
URL : http://www.intel.com
Speed : 1.86GHz
Peak Processing Performance (PPP) : 14.9GFLOPS
Adjusted Peak Performance (APP) : 4.47WG
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Dual-Core
Bus : Intel AGTL+
Package : FC LGA775
Maximum Speed : 1.86GHz / 4x 267MHz (1GHz)
Multiplier : 7x
Minimum/Maximum/Turbo Multiplier : 6x - 7x
Generation : G8
Name : C2DC (Conroe) Core 2 Duo 65nm 2.4-3.33GHz 1.0375-1.3V
Revision/Stepping : 0 / F / 6
Stepping Mask : B2
Microcode : MU060F06CB
Core Voltage Rating : 1.325V
Min/Max Core Voltage : 0.825V - 1.325V
Maximum Power : 45.70W
Maximum Physical / Virtual Addressing : 36-bit / 48-bit
Native Page Size : 4kB
Large Page Size : 2MB
Co-Processor (FPU)
Speed : 1.86GHz
Type : Integrated
Cache Information
Integrated Data Cache : 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
Integrated Instruction Cache : 32kB, Synchronous, Write-Back, 8-way, 64 byte line size
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L2 Cache Multiplier : 1x
Upgradeability
Socket/Slot : Socket 775
Supported Speed(s) : 1.86GHz
Sensors 1
Model : Winbond W83627EHG ISA
Version : 10.01
Mainboard Specific Support : No
Sensors 2
Model : Intel Core CPU [P0, C2, T70]
Version : 15.06
Power Rating(s)
CPU Core Power : 44.98W
Sensors
CPU 1 Temperature : 35.00°C td
CPU 1 DC Line : 1.31V
Features
FPU - Integrated Co-Processor : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange 8-bytes Instruction : Yes
APIC - Local APIC Integrated : Yes
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
CLF - Cache Line Flush Support : Yes
DS - Debug Trace & EMON Store : Yes
ACPI - Software Clock Control : Yes
(W)MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : Yes
SS - Self Snoop : Yes
HTT - Hyper-Threading Technology : Yes
TM - Thermal Monitor : Yes
PBE - Pending Break Enable : Yes
IA64 Technology : No
SSE3 Technology : Yes
PCLMULQDQ - Carryless Multiplication : No
MON - Monitor/MWait : Yes
DSCPL - CPL qualified Debug Store : Yes
VMX - Virtual Machine eXtensions : Yes
SMX - Trust Execution Technology : No
EIST - Enhanced SpeedStep Technology : Yes
TM2 - Thermal Monitor 2 : Yes
Supplemental SSE3 Technology : Yes
CID - Context ID : No
FMA - Fused Multiply/Add eXtensions : No
CX16 - Compare & Exchange 16-bytes Instruction : Yes
xTPR - Send Task Priority Messages : Yes
PDCM - PerfMon and Debug : Yes
DCA - Direct Cache Access : No
SSE4.1 Technology : No
SSE4.2 Technology : No
x2APIC - v2 APIC Mode : No
MOVBE - Byte-swap Load/Store : No
POPCNT - Pop Count : No
AES - Cryptography Support : No
XSAVE - eXtended State Management : No
OSXSAVE - OS Enabled eXtended States : No
AVX - Advanced Vector eXtensions : No
CVT16 - Half Precision Float Conversion : No
GIH - Guest in Hypervisor : No
DAZ - Denormals Are Zero : Yes
Extended Features
EMMX - Extended MMX Technology : No
3DNow! Technology : No
Extended 3DNow! Technology : No
XD/NX - No-execute Page Protection : Yes
AMD64/EM64T Technology : Yes
RDTSCP - Serialised TSC : No
P1GB - 1GB Large Page Support : No
SVM - Secure Virtual Machine : No
AltMovCr8 - Lock Move CRn : No
ABM - Advanced Bit Manipulation : No
SSE4A Technology : No
MASSE - Misaligned SSE Mode : No
3D Now! Prefetch Technology : No
XOP - eXtended OPerations : No
LWP - LightWeight Profiling Support : No
FMA4 - 4 Operands Fused Multiply/Add eXtensions : No
TCE - Translation Cache eXtension : No
NID - Multi-Node Support : No
ToP - Extended Topology : No
Power Management Features
DTSC - Digital Thermal Sensor Capability : Yes
IDA - Dynamic Acceleration Technology : No
HCFC - Hardware Coordination Feedback/Effective Frequency : Yes
Virtual Machine Features
Version : 0.07
Address Width Limited to 32-bit : No
Dual-Monitor Interrupts/System Management Mode : Yes
Report Information on VMExit : No
Ex Capability MSR Supported : No
Advanced Settings
Fast Strings : Yes
PM - Performance Monitoring Support : Yes
PEBS - Precise Event Based Sampling Support : Yes
XE Operation Enabled : No
Hardware Prefetcher Enabled : Yes
Adjacent Cache Line Prefetch Enabled : Yes
Data Cache Prefetcher Enabled : Yes
Instruction Prefetcher Enabled : Yes
Average Clock Speed : 96.72%
Symmetric Multiprocessing (SMP) Settings
Bootstrap CPU : Yes
Global APIC Engaged : Yes
APIC ID : 0 : P0C0T0
Cluster ID : 0
Symmetric Arbitration ID : 0
Memory Range : 00000000FEE00000
Machine Check Architecture Settings
Number of Reporting Banks : 6
Variable Range MTRR Settings
MTRR 0 : 00000000-7FFFFFFF WB
MTRR 1 : 7FF00000-7FFFFFFF UC
MTRR 2 : D0000000-D7FFFFFF WC
additional info
i have a 350w psu
Mainboard
Manufacturer : Fujitsu Siemens
URL : http://www.fujitsu-siemens.com
Multi-Processor (MP) Support : No
Multi-Processing (MPS) Version : 1.40
Model : MS-7293VP
Version : 2.00
BIOS : 03/09/2007-PT890-8237A-6A7L8M4BC-00
will they work thanks!
SiSoftware Sandra
Processor
Speed : 1.86GHz
Type : Dual-Core
Bus : Intel AGTL+
Package : FC LGA775
Multiplier : 7x
Generation : G8
Stepping Mask : B2
Co-Processor (FPU)
Speed : 1.86GHz
Type : Integrated
Cache Information
Upgradeability
Sensors 1
Version : 10.01
Sensors 2
Version : 15.06
Power Rating(s)
Sensors
Features
Extended Features
Version : 0.07
Advanced Settings
Fast Strings : Yes
Bootstrap CPU : Yes
Cluster ID : 0
additional info
i have a 350w psu
Mainboard
Model : MS-7293VP
Version : 2.00
