Solved
Help with Connecting SATA Harddrive and CD/DVD-RW drive
  • Homebuilt
  • SATA
  • DVD RW
  • Burner
  • Hard Drives
  • CD-Rom
  • Systems
  • Product
Last response: in Systems
June 9, 2011 5:25:00 PM
I need to make sure I've plugged my drives into the correct place on the mobo.
I have this Gigabyte Z68 mobo
http://www.gigabyte.com/products/product-page.aspx?pid=...
This burner drive
And this hard drive
Currently I've connected it like this:
Harddrive SATA 3.0Gb/s - mobo SATA3-0
Burner SATA - mobo SATA3-1
I don't really understand the difference amongst the various SATA connections on the mobo. It has:
SATA3-0/1
SATA2-2/3/4
GSATA-5/6
More about : connecting sata harddrive dvd drive
Best solution
a b B Homebuilt system
June 9, 2011 5:36:10 PM
That will be fine. SATA ports make things a lot easier for us all - you can really plug those two drives in wherever you'd like. It's mostly just if you have an expensive SSD that needs a SATA3 port that you'll have to be a bit picky.
June 14, 2011 4:14:17 PM
Best answer selected by pater familias.
m
l
