Help finding compatible chipset
For my M4AT2 motherboard. I looked everywhere on ASUS and came up blank. The internet doesn't seem to think it even exists. :??:
1 answer Last reply
More about help finding compatible chipset
  1. Are you completely sure that is your motherboard product number?
    If so, it is certainly far outside of their regular naming conventions.
    Usually it is more like M4A68T or something like that. There are usually 2 numbers between the A and the T.
Chipsets Compatibility Motherboards Internet
