Hey guys, pretty new here so don't really know what to say and whatnot but I appear to have made a small mistake.
I bought this motherboard to start an i5 build: Gigabyte Ga-H61M-D2H-Usb3
(http://www.gigabyte.com/products/product-page.aspx?pid=4004#ov)
Now my friend runs the same system as what i want to build (only his is an i7) and he told me to buy this RAM: Patriot Memory G2 DDR3 1333Mhz
(http://patriotmemory.com/products/detailp.jsp?prodline=5&catid=34&prodgroupid=196&id=1050&type=1)
Now the problem i have is the board has a recommended DIMM socket voltage of only 1.5V and the RAM that i have ordered is 1.65V, my friends system works great with the same 2 components but i just don't want to have any problems so i though i would come to you guys for help. Will the RAM i have ordered still work in my system or will i have to buy new RAM? Can i mess with the voltage to make things work stably or would that not be a wise thing to do?
All help would be much appreciated, thanks, Camron.
