I need some tips for a wireless network, The Toshiba Satellite C655 can connect with a B, G or N routers but I don’t which to choose any advice for me everyone?
As a general rule, B is old hat, G is adequate but fast beikng superceded and N is the one that future proofs you to a degree. [/#000ff]
Ok so go with the N routers but what do you mean by "to a degree" and how fast does an N router go?
To a degree means the next big thing is always only just around the corner and might have been invented last night for all I know. We can never stay ahead of the technological game for very long, I'm afraid but N is going to be sufficient for normal needs for a couple of years, I daresay.
For what it's worth, it's supposed to have increased it's maximum raw data rate from 54 Mbit/s to 600 Mbit/s with the use of four spatial streams at a channel width of 40 MHz. That's one big increase so it will probably not be surpassed this week. [/#000ff]
