G
Guest
Guest
HELP NEEDED!
Hi guys, I just bought the ASUS GTX560 TI TOP yesterday.
The "TOP" version of the card should be running at 900MHz and the shader at 1800HMz
http://www.asus.com/product.aspx?P_ID=2oRA7x6MYEwAq4mL&templete=2
BUT, when I run ASUS's "smart doctor" or GPU-Z, it shows that mine is only running at 830MHZ and shader at 1660MHz
(Exactly like the cheaper stock version)
Screenshot of GPU-Z: http://img806.imageshack.us/i/37361466.jpg/
I checked the serial number on the card (the small sticker)
And the one I got IS suppose to be the "TOP" version.
So why is it running at stock speed? When it’s supposed to run faster?
I have seen quite a few online tests of the card online.
Like this one:
http://benchmarkreviews.com/index.p...sk=view&id=697&Itemid=72&limit=1&limitstart=5
Where you can see it running at the correct speed in GPU-Z.
I have heard that ASUS's VGA cards underclock themselves in idle?
I haven’t had the time to max out the cards performance, to see if the speed will change.
I don’t know if I should return the card, or what I am supposed to do. I really hope you guys can help me.
Or have an idea of what’s going on!
Like this one:
