Hi, I'm attempting to build a computer for the first time. Unfortunately, I don't know much about it, and I'm not sure if these parts are compatible with each other.
My goal is to build a pretty good gaming computer (that I'll also use for schoolwork, watching movies, etc) while keeping the price relatively low (although I can go as high as $1,500, but would prefer to stay around $1,000). My current expected cost with the parts listed below is about $1,100, however, I added $3-5 to each part in anticipation of things like tax, shipping cost, etc. Not sure how accurate that is, but whatever.
I'd like to be able to run Battlefield 3 when it comes out at medium or higher graphics with 100ish fps. Since I don't really know what I'm doing, I'd like to stay away from multiple graphics cards, overclocking, etc.
My questions are:
-will all these parts work together
~including things like fitting in the case, enough slots on the motherboard
-should I use the sound card listed, onboard sound, or a higher end sound card
~I need to be able to hear things like footsteps in 1st person shooters
effectively, and I'd like good quality when listening to music on my Sennheisers
-are there any parts I'm missing that I may want/need?
~Already have a mouse, keyboard, mic, speakers/headset, copy of Windows 7 64 bit
-Is a 750 watt power supply sufficient, or overkill?
My list of parts:
Power Supply
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Motherboard
ASUS P7H55-M PRO LGA 1156 Intel H55 HDMI Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=13-131-623&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
Video Card
XFX HD-687A-ZNFC Radeon HD 6870 1GB 256-bit DDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?item=N82E16814150506
Hard drive
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=22-148-433&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
Processor
Intel Core i7-870 Lynnfield 2.93GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor BX80605I7870
http://www.newegg.com/Product/Product.aspx?item=N82E16819115213
DVD
LITE-ON 24X DVD Writer 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS424-98 LightScribe Support
http://www.newegg.com/Product/Product.aspx?item=N82E16827106335
Sound Card
ASUS XONAR_DG 5.1 Channels PCI Interface Xonar DG Sound Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020&cm_re=asus_xonar-_-29-132-020-_-Product
CPU Cooler
ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler
http://www.newegg.com/Product/Product.aspx?item=N82E16835118019
Case
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?item=N82E16811129021
RAM
Kingston HyperX Blu 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model KHX1333C9D3B1K2/8G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104231
Sorry if I posted this in the wrong place, or made any format errors or anything; It's my first time using this site.
Thank you for your time,
-Ryan
My questions are:
My list of parts:
Power Supply
Motherboard
Video Card
Hard drive
Processor
DVD
Sound Card
CPU Cooler
Case
RAM
-Ryan
