Closed Solved
Assistance with suspect inferior PSU problem, thank you.
Hi All,
I have a problem I would like direction with. I have an Asus CG5270. Everything inside is still what came stock. I am encountering issues when running anything graphics intensive (I will use Witcher 2 for this example, but this issue is not limited to gaming nor is it limited to Witcher 2... this is also triggered by using Street View in Google Maps and is causing me to be unable to effectively do my job - in which I regularly use Google Maps Street View).
Order of events:
1.) Boot PC - all functions normally
2.) Start Witcher 2 - initially functions okay... after about 30 seconds the fans kick into high speed and the graphics and responses lag.
3.) Monitor goes blank, enters power save mode (which happens on any monitor I connect in my tests), sound remains for about 5 seconds and then all power is lost.
4.) Fans are still running but power is lost to the rest of the PC.
5.) Hard power off, wait 30 seconds to a minute then power on (only way to get this to stop and bring Windows back up)
I believe that my power supply (stock 400 watt) is not sufficient enough to run the graphics card at the correct performance level to meet my graphics needs. I have a NVIDIA GeForce GT 220, which, per Nvidia, requires 350 watts. Considering most PSUs built into pre-bundled PCs never provide their maximum wattage for extended periods of time, I deduct that the inferior PSU is the problem.
I have copied fairly detailed system specs below. I removed registers (all except chipset) for space saving. All drivers are up to date. Only BIOS needs to be updated.
I am specifically seeking:
1.) Affirmation or negation of my deducted belief.
2.) Anyone with experience in this area's knowledge shared (knowledge gained is always valued).
3.) Advice on a new PSU (purchasable in Alberta, Canada) that will do more than just scrape by but is affordable and compatible with my PC (I believe I cannot go thicker than 120 mm with this case).
I, in advance, thank all those who contribute. Your time is greatly appreciated and valued.
Regards,
Amanda
CPU-Z TXT Report
Binaries
CPU-Z version 1.58
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q8300
Codename Yorkfield
Specification Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
Package (platform ID) Socket 775 LGA (0x4)
CPUID 6.7.A
Extended CPUID 6.17
Core Stepping R0
Technology 45 nm
TDP Limit 95 Watts
Core Speed 1998.0 MHz
Multiplier x FSB 6.0 x 333.0 MHz
Rated Bus speed 1332.0 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 7.5x
Max VID 1.288 V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008005h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008005h
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01008005h
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01008005h
Chipset
Northbridge Intel P45/P43/G45/G43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 8192 MBytes
Channels Dual, (Symmetric)
Memory Frequency 399.6 MHz (5:6)
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 18
Row Refresh Cycle Time (tRFC) 52
Command Rate (CR) 2T
MCHBAR I/O Base address 0x0FED14000
MCHBAR I/O Size 4096
MCHBAR registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10 00 00 00 80 1F 46 10 00 F7 37 64 DF 00 00 00 00
20 01 30 01 00 00 00 00 60 00 00 00 00 62 4A 04 00
30 86 5A 1F 00 10 28 90 01 00 00 00 F7 10 44 01 65
40 18 80 03 8B 00 C0 6B 00 02 00 00 00 00 00 00 00
50 01 00 80 00 02 01 8F 00 00 00 00 00 00 00 00 00
60 04 02 80 00 08 03 8F 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 55 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 40 12 00 00 D8 00 00 00 00 00 00 00 00 00
B0 00 00 D8 00 00 00 00 00 00 00 00 00 00 00 D8 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 00 00 00 00 00 20 00 00 00 10 00 10 00 00 00 00
110 45 AC 00 00 00 9A 00 AA 58 21 7E 81 00 08 7D 00
120 5F 7F 8D 50 07 E0 3B 40 05 1F 80 00 A0 66 00 5E
130 A2 FF A9 9F 00 3C A6 29 A1 8F 71 40 9E 8F 51 40
140 CC 82 32 01 8A 22 2A 01 E0 17 73 01 5D A7 6A 01
150 00 00 00 00 00 00 00 00 00 00 00 00 03 31 14 06
160 99 09 00 00 22 16 1B 16 00 00 00 00 00 00 00 00
170 00 00 00 00 FF 73 00 00 35 01 00 00 00 FF FF FF
180 04 0D C8 00 FF FF FF FF 11 BF 0F 0F 00 00 00 00
190 00 00 01 0F 33 00 00 00 AA AA AA 22 19 32 00 00
1A0 03 18 55 00 40 00 00 00 F1 00 00 00 FF 10 00 30
1B0 00 03 00 00 C0 31 00 00 00 00 00 00 02 04 06 08
1C0 20 03 00 00 00 80 00 00 05 00 00 00 00 00 00 00
1D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
200 10 00 20 00 30 00 40 00 86 86 86 86 00 00 00 00
210 3F 00 7F FF 00 00 00 00 00 00 00 00 00 00 00 00
220 17 11 00 58 02 03 23 00 02 00 00 00 00 00 00 00
230 00 00 00 00 00 00 00 00 00 14 00 00 89 7B 00 00
240 03 11 00 01 10 23 05 00 33 68 C6 0E 00 22 43 00
250 D5 03 34 CE 06 04 68 64 46 C5 0C 34 0E 12 A5 15
260 C8 3C F7 0B 89 00 0C 13 4A 30 CC CF 33 5F 55 03
270 00 0E 55 01 01 87 08 00 81 18 14 88 41 00 04 48
280 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
290 1C 09 F2 04 11 11 00 00 44 44 00 00 6B 06 00 00
2A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2B0 00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 00
2C0 F0 C5 0C 48 7C 00 00 00 00 00 00 00 00 00 00 00
2D0 00 31 28 FF 00 36 45 40 00 00 00 00 00 00 00 00
2E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
300 08 0A 0B 0C 01 02 04 06 00 00 00 00 05 14 04 A9
310 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 0A 00
320 00 00 00 00 00 00 00 00 00 00 04 04 04 04 05 05
330 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
340 07 08 09 0A 0B 0C 0D 0E 0F 10 04 04 04 04 05 05
350 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
360 07 08 09 0A 0B 0C 0D 0E 0F 10 00 00 00 00 00 00
370 00 00 00 00 00 A0 00 00 AA AA 00 00 00 00 00 00
380 00 00 02 02 02 02 02 02 02 03 03 03 04 04 05 05
390 06 06 02 02 02 02 02 02 03 03 03 04 04 04 05 05
3A0 06 06 01 A0 00 00 77 77 00 00 00 00 00 00 00 00
3B0 02 02 02 02 02 02 02 03 03 03 04 04 05 05 06 06
3C0 02 02 02 02 02 02 03 03 03 04 04 04 05 05 06 06
3D0 01 A0 00 00 77 77 00 00 00 00 00 00 00 00 02 02
3E0 02 02 02 02 02 03 03 03 04 04 05 05 06 06 02 02
3F0 02 02 02 02 03 03 03 04 04 04 05 05 06 06 00 A0
400 00 00 77 77 00 00 00 00 00 00 00 00 03 03 03 04
410 04 04 04 05 05 06 07 07 08 08 09 09 02 02 03 03
420 03 03 04 05 05 06 07 07 08 08 08 08 00 A0 00 00
430 77 77 00 00 00 00 00 00 00 00 03 03 03 04 04 04
440 04 05 05 06 07 07 08 08 09 09 02 02 03 03 03 03
450 04 05 05 06 07 07 08 08 08 08 12 00 00 00 12 00
460 00 00 12 00 00 00 12 00 00 00 00 00 00 00 00 00
470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
480 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
490 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4B0 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
4C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
500 59 59 59 59 39 39 39 39 69 69 69 69 0A 0A 0A 0A
510 3A 3A 3A 3A 58 58 58 58 38 38 38 38 47 47 47 47
520 52 52 52 52 62 62 62 62 03 03 03 03 03 03 03 03
530 33 33 33 33 02 02 02 02 31 31 31 31 30 30 30 30
540 44 77 6D 00 55 77 92 00 44 77 FF 00 44 77 6D 00
550 44 77 24 00 44 77 24 00 44 77 92 00 55 77 00 00
560 70 00 00 00 71 00 00 00 71 80 00 00 78 80 00 00
570 79 00 00 00 79 00 00 00 7A 00 00 00 76 80 00 00
580 41 5B 5B 00 50 50 50 50 00 00 00 00 15 40 00 00
590 55 55 3C 1E 68 00 00 80 00 33 00 00 00 C0 F1 00
5A0 10 0C 00 00 00 20 00 00 00 20 00 00 00 20 00 00
5B0 00 20 00 00 FF FE 01 00 FF FE 01 00 FF FE 01 00
5C0 FF FE 01 00 07 18 00 00 55 55 55 55 55 55 55 55
5D0 55 55 55 55 55 55 55 55 0F 72 00 00 80 3F 00 00
5E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
5F0 FC 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00
600 10 00 20 00 30 00 40 00 86 86 86 86 00 00 00 00
610 32 02 64 28 00 00 00 00 00 00 00 00 00 00 00 00
620 17 11 00 58 02 03 23 00 02 00 00 00 00 00 00 04
630 00 00 00 00 00 00 00 00 00 14 00 00 89 7B 00 00
640 03 11 00 01 10 23 25 00 33 68 C6 0E 00 22 43 00
650 D5 03 34 CE 06 04 68 64 46 C5 0C 34 0E 12 A5 15
660 C8 3C F7 0B 89 00 0C 13 4A 30 CC CF 33 5F 55 03
670 00 0E 55 01 01 87 08 00 81 18 14 88 41 00 04 48
680 00 00 00 00 00 00 00 00 00 02 04 08 10 20 40 FF
690 1C 09 F2 04 11 11 00 00 44 44 00 00 6B 06 00 00
6A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6B0 00 00 00 00 00 00 00 00 00 18 06 00 70 70 70 01
6C0 A0 34 20 80 02 00 00 00 00 00 00 00 00 00 00 00
6D0 00 00 1D 28 00 00 00 00 00 00 00 00 00 04 02 10
6E0 00 00 00 00 00 04 02 10 00 00 00 02 00 01 04 00
6F0 00 00 00 02 00 01 04 00 00 00 00 00 00 00 00 00
700 00 00 00 00 00 00 00 00 00 00 00 00 00 02 10 08
710 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 0A 00
720 00 00 00 00 00 00 00 00 00 00 04 04 04 04 05 05
730 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
740 07 08 09 0A 0B 0C 0D 0E 0F 10 04 04 04 04 05 05
750 05 06 07 08 09 09 0A 0B 0C 0D 04 04 04 04 05 06
760 07 08 09 0A 0B 0C 0D 0E 0F 10 00 00 00 00 00 00
770 00 00 00 00 00 A0 00 00 AA AA 00 00 00 00 00 00
780 00 00 02 02 02 02 02 02 02 03 03 03 04 04 05 05
790 06 06 02 02 02 02 02 02 03 03 03 04 04 04 05 05
7A0 06 06 01 A0 00 00 77 77 00 00 00 00 00 00 00 00
7B0 02 02 02 02 02 02 02 03 03 03 04 04 05 05 06 06
7C0 02 02 02 02 02 02 03 03 03 04 04 04 05 05 06 06
7D0 01 A0 00 00 00 00 00 00 00 00 00 00 00 00 02 02
7E0 02 02 02 02 02 03 03 03 04 04 05 05 06 06 02 02
7F0 02 02 02 02 03 03 03 04 04 04 05 05 06 06 00 A0
800 00 00 77 77 00 00 00 00 00 00 00 00 03 03 03 04
810 04 04 04 05 05 06 07 07 08 08 09 09 02 02 03 03
820 03 03 04 05 05 06 07 07 08 08 08 08 00 A0 00 00
830 00 00 00 00 00 00 00 00 00 00 03 03 03 04 04 04
840 04 05 05 06 07 07 08 08 09 09 02 02 03 03 03 03
850 04 05 05 06 07 07 08 08 08 08 12 00 00 00 12 00
860 00 00 12 00 00 00 00 00 00 00 00 00 00 00 00 00
870 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
880 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
890 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8B0 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
8C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
900 0A 0A 0A 0A 3A 3A 3A 3A 1A 1A 1A 1A 0A 0A 0A 0A
910 1A 1A 1A 1A 38 38 38 38 37 37 37 37 17 17 17 17
920 52 52 52 52 62 62 62 62 03 03 03 03 03 03 03 03
930 33 33 33 33 02 02 02 02 31 31 31 31 30 30 30 30
940 44 77 6D 00 55 77 24 00 44 77 6D 00 44 77 24 00
950 55 77 00 00 55 77 92 00 44 77 24 00 55 77 92 00
960 79 80 00 00 7C 00 00 00 7C 00 00 00 7C 00 00 00
970 70 00 00 00 70 80 00 00 77 80 00 00 7B 00 00 00
980 41 5B 5B 00 50 50 50 50 00 00 00 00 00 5A 00 00
990 55 55 1C 1E 68 00 00 80 00 33 00 00 00 C0 F1 00
9A0 10 0C 00 00 00 04 00 00 00 04 00 00 00 04 00 00
9B0 00 04 00 00 FF FE 01 00 FF FE 01 00 FF FE 01 00
9C0 FF FE 01 00 07 18 00 00 55 55 55 55 55 55 55 55
9D0 55 55 55 55 55 55 55 55 0F 72 00 00 00 3F 00 00
9E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9F0 FC 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 00 00
A10 00 00 00 04 00 01 00 00 00 00 00 00 00 00 00 00
A20 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00
A30 18 06 00 44 00 00 00 00 00 00 00 00 00 00 00 00
A40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A50 00 00 01 00 00 00 00 00 00 00 00 00 90 01 00 00
A60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AB0 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00
AC0 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00
AD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
AE0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00
AF0 88 00 00 00 E6 00 00 00 5C 00 00 00 3F 00 00 00
B00 00 00 00 00 00 00 89 00 00 00 00 00 00 00 00 00
B10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B20 00 00 00 00 00 00 00 00 89 00 00 00 00 00 00 00
B30 00 00 00 00 00 00 00 00 00 00 81 00 00 00 00 00
B40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B50 08 00 08 00 08 00 08 00 08 00 08 00 00 00 00 00
B60 10 00 00 00 00 00 00 00 00 00 00 44 44 00 00 00
B70 00 00 00 00 41 00 00 18 00 00 00 00 00 00 00 00
B80 00 01 02 03 04 05 06 07 08 09 0A 0C 0E 11 14 17
B90 1A 1E 22 26 2A 2E 32 36 3A 3C 3D 3E 3F 3F 3F 3F
BA0 00 01 02 03 04 05 06 07 08 09 0A 0C 0E 10 12 14
BB0 17 19 1B 1E 21 24 27 2A 2D 30 33 36 3A 3C 3E 3F
BC0 31 4D 31 4D 31 4E 31 31 4D 31 4D 00 00 00 00 00
BD0 0E 0E 0C 0C 33 33 00 00 0E 0E 0E 0E 0E 0E 0E 0E
BE0 1C 26 56 BF 00 00 00 00 00 00 00 00 00 00 00 00
BF0 00 00 00 00 FF FF 10 84 10 10 10 10 10 10 10 10
C00 34 24 01 00 07 07 0B 0D 80 00 00 00 00 00 00 00
C10 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00
C20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C30 05 00 00 00 00 00 00 00 01 00 00 00 80 C1 00 00
C40 00 80 00 02 00 00 00 00 00 80 00 00 00 00 00 00
C50 2F 1F 1F 3E 00 00 01 01 00 00 00 00 00 00 00 00
C60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C80 01 01 01 01 00 00 00 00 00 00 00 00 00 02 00 00
C90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CD0 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00
CE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CF0 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
D00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DF0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E00 00 00 00 00 00 00 00 00 44 00 00 00 C4 01 00 03
E10 00 32 22 00 00 00 00 00 00 00 00 00 00 00 00 00
E20 00 00 00 00 00 00 00 00 00 00 00 00 C0 6D A9 01
E30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E60 F0 0F 00 00 00 F0 00 00 0F 00 00 00 00 00 00 00
E70 FF FF FF FF FF FF 13 00 20 F0 00 01 00 00 00 00
E80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EA0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EC0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ED0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EE0 00 00 00 00 00 00 00 00 00 00 68 06 00 00 00 00
EF0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F00 3C 3B 3A 39 40 3F 3E 3D 3C 3B 3A 39 40 3F 3E 3D
F10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F20 FF FF FF 3F 00 00 00 00 00 00 00 00 00 00 00 00
F30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F40 00 00 00 00 00 00 00 00 E0 FF F0 FF 00 FF C0 FF
F50 00 F0 00 FC 00 80 00 C0 00 00 00 00 00 00 00 00
F60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF
F70 FF FF FF 0F FF 7F 00 00 00 00 00 00 00 00 00 00
F80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FA0 02 00 02 00 C3 00 91 21 00 D4 30 00 00 00 10 40
FB0 25 D0 00 10 42 C8 00 00 00 00 00 00 0F F0 00 00
FC0 80 40 13 80 44 22 E2 0F 00 00 00 00 00 00 00 00
FD0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FE0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
FF0 00 00 00 00 00 00 00 00 00 00 E0 2F 00 00 00 00
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) Nanya Technology (7F7F7F0B00000000)
Size 2048 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number NT2GT64U8HD0BY-AD
Serial number D7562924
Manufacturing date Week 12/Year 09
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 4.0-4-4-12-16 @ 266 MHz
JEDEC #2 5.0-5-5-15-20 @ 333 MHz
JEDEC #3 6.0-6-6-18-24 @ 400 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Size 2048 MBytes
Serial number E8562923
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 3
SMBus address 0x52
Memory type DDR2
Size 2048 MBytes
Serial number A2592921
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
DIMM # 4
SMBus address 0x53
Memory type DDR2
Size 2048 MBytes
Serial number 92592922
Number of banks 2
Data width 64 bits
Correction None
EPP no
XMP no
Monitoring
Mainboard Model CG5270 (0x00000158 - 0x0055D400)
LPCIO
LPCIO Vendor Winbond
LPCIO Model W83627DHG-P
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xB0
LPCIO Revision ID 0x73
Config Mode I/O address 0x2E
Config Mode LDN 0xB
Hardware Monitors
Hardware monitor Winbond W83627DHG
Voltage 0 1.26 Volts [0x9D] (CPU VCORE)
Voltage 1 1.89 Volts [0xEC] (VIN1)
Voltage 2 3.34 Volts [0xD1] (+3.3V)
Voltage 3 5.02 Volts [0xD1] (+5V)
Voltage 4 8.31 Volts [0x95] (+12V)
Voltage 5 1.58 Volts [0xC5] (VIN5)
Voltage 6 1.05 Volts [0x83] (VIN6)
Temperature 0 39°C (102°F) [0x27] (SYSTIN)
Temperature 1 50°C (122°F) [0x64] (CPUTIN)
Temperature 2 98°C (208°F) [0xC4] (AUXTIN)
Fan 1 1223 RPM [0x8A] (CPUFANIN0)
Hardware registers
Register space LPC, base address = 0x0290
bank 0
Hardware monitor NVIDIA I/O
Temperature 0 48°C (118°F) [0x30] (TMPIN0)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.80 Volts [0x320] (VIN0)
Fan PWM 0 40 pc [0x28] (FANPWMIN0)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Description PCI to PCI Bridge
Location bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Description USB Controller (UHCI)
Location bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Location bus 0 (0x00), device 26 (0x1A), function 1 (0x01)
Location bus 0 (0x00), device 26 (0x1A), function 2 (0x02)
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 26 (0x1A), function 7 (0x07)
Description Multimedia device
Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Location bus 0 (0x00), device 28 (0x1C), function 5 (0x05)
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Location bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Location bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Location bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Description IDE Controller
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Location bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Description Ethernet Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
DMI
DMI BIOS
vendor American Megatrends Inc.
version 0206
date 05/12/2009
DMI System Information
manufacturer ASUSTeK Computer INC.
product CG5270
version Rev X.0x
serial System Serial Number
UUID {71ABC8C0-6500-11DE-B369-002618C1B4F1}
DMI Baseboard
vendor ASUSTeK Computer INC.
model CG5270
revision Rev X.0x
serial MT7096K17400127
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
clock speed 2500.0 MHz
FSB speed 333.0 MHz
multiplier 7.5x
DMI Port Connector
designation PS/2 Keyboard (internal)
designation PS/2 Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation LPT (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation COM 1 (internal)
designation COM 1 (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation GbE LAN (internal)
designation GbE LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation USB1_2 (internal)
designation USB1_2 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB3_4 (internal)
designation USB3_4 (external)
port type USB
DMI Port Connector
designation Audio_Line In (internal)
designation Audio_Line In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio_Line Out (internal)
designation Audio_Line Out (external)
DMI Port Connector
designation Audio_Mic In (internal)
designation Audio_Mic In (external)
DMI Port Connector
designation Center/LFE Speaker (internal)
designation Center/LFE Speaker (external)
DMI Port Connector
designation Rear Speaker (internal)
designation Rear Speaker (external)
DMI Port Connector
designation Side Speaker (internal)
designation Side Speaker (external)
DMI Port Connector
designation SPDIF_OUT (internal)
designation SPDIF_OUT (external)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation SPDIFO (internal)
designation SPDIFO (external)
DMI Port Connector
designation DVI (internal)
designation DVI port (external)
DMI Port Connector
designation HDMI (internal)
designation HDMI port (external)
DMI Port Connector
designation SATA1 (internal)
DMI Port Connector
designation SATA2 (internal)
DMI Port Connector
designation SATA3 (internal)
DMI Port Connector
designation SATA4 (internal)
DMI Port Connector
designation SATA5 (internal)
DMI Port Connector
designation SATA6 (internal)
DMI Port Connector
designation PRI_EIDE (internal)
connector On Board IDE
DMI Port Connector
designation USB5_6 (internal)
port type USB
DMI Port Connector
designation USB7_8 (internal)
port type USB
DMI Port Connector
designation USB9_10 (internal)
port type USB
DMI Port Connector
designation USB11_12 (internal)
port type USB
DMI Port Connector
designation PANEL (internal)
connector 9 Pin Dual Inline (pin 10 cut)
DMI Port Connector
designation CHASSIS (internal)
DMI Port Connector
designation CD (internal)
DMI Port Connector
designation AAFP (internal)
DMI Port Connector
designation CPU_FAN (internal)
DMI Port Connector
designation PWR_FAN (internal)
DMI Port Connector
designation CHA_FAN (internal)
DMI Extension Slot
designation PCIEX16_1
type A5
width 64 bits
populated yes
DMI Extension Slot
designation PCIEX1_1
type A5
width 32 bits
populated no
DMI Extension Slot
designation PCI_1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI_2
type PCI
width 32 bits
populated no
DMI OEM Strings
string[0] To Be Filled By O.E.M.
string[1] 02AI010FBFF1000000
string[2] To Be Filled By O.E.M.
string[3] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 16384 MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
DMI Memory Device
designation DIMM3
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 2048 MBytes
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GT 220
Revision A2
Codename GT216
Technology 40 nm
Memory size 1024 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x0A20 (0x82F3)
Performance Level Default
Core clock 135.0 MHz
Shader clock 270.0 MHz
Memory clock 135.0 MHz
Performance Level 2D Desktop
Core clock 405.0 MHz
Shader clock 810.0 MHz
Memory clock 324.0 MHz
Performance Level 3D Applications
Core clock 615.0 MHz
Shader clock 1335.0 MHz
Memory clock 790.0 MHz
Software
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 2 (Build 6002)
DirectX Version 11.0
6 answers Last reply Best Answer
More about assistance suspect inferior problem
  1. Best answer
    In the above it states your 12v line at8.3v .Not good. But not believable either.
    Could be the ps failing but temp 2 at 98 celsius is kind of scary.
    Check the fan and heatsink on the video card. It may be clogged or the fan not working. It may need new thermal paste, the cheap stuff dries out.
  2. Hi Rick,
    Thank you for replying. The 12v line has run high like that since I purchased this PC a year and a half ago. The fan RPM has also been well above threshold the entire time as well. The current CPU fan speed is 1222 RPM, about double the recommended for that fan. The heatsink and fan are in tact and functioning as far as I can tell. My PC in general is well kept by me https://docs.google.com/leaf?id=0B7en40YFdhiDYWJkZDkxN2QtOTdkMC00ZmJkLTkzMzEtMTg2MjgyYTQzNGM1&hl=en_US there is a link to a photo I took a few minutes ago. This is the condition when I open it. There was one small dust piece on the CPU fan. :-) I am a bit particular about keeping things clean. Not sure where to go from here.
    Gratefully,
    Amanda
  3. unless your measuring 12v with a multimetre then its not accurate. if it were 8.3v then the pc wouldnt ever have worked. you have a fairly low powered system, i think its a heat problem.
  4. So today I swapped (for testing) my power supply with my husband's (his is a Antec TP 650W) and everything in my PC worked fine. I loaded Google Maps Street View without problems and then ran Witcher 2 at top video settings. Again, no power loss. So I purchased an Antec Earthwatts 750W Power Supply (which comes with a 135mm fan instead of the 120mm), installed it and have had absolutely no shut downs. As added caution to the temperature I installed two 120mm case fans (connected to the MoBo, so they are speed controlled; 38 CFM each, so sufficient); one in the front sucking cool air in and one in the back sucking warm air out. I would say today has been a productive day. Tomorrow will be better... uninterrupted work.
    Thank you for your contributions and your time.
    Regards,
    Amanda
  5. Best answer selected by amandawilborn.
  6. This topic has been closed by Mousemonkey
Power Supplies Components
