I built my computer a few weeks ago and I experienced a boot loop problem, I wasn't sure what it was so I tried to replicate it by powering the computer down and unplugging it, and then starting it back up again. After a few attempts I thought to power down the computer and to drain all power by pressing the power button once I had disconnected the power cable. When I attempted to turn the computer back on nothing happened, no led's turned on and the PSU refused to start. I waited 15 minutes and it powered on. I tried it again just to check that something is wrong, and sure enough it happened again.
I have checked that the power signal wire from the case is correctly plugged into the motherboard and that the wire is undamaged. My case does not have a system speaker, so I'm unsure if any errors have occurred.
Is this a problem with the motherboard? or could it just be the CMOS battery is dead. I will be swapping out the PSU later today to test that my current one isn't faulty.
My computer
CPU: i5 2500k @ stock speeds
GPU: MSI Twin Frozr ii 560Ti
RAM: 8GB Corsair Vengeance @1600MHz
HDD: 500GB Seagate
PSU: OCZ ZS 650W
CASE: Fractal R3 Design
MOBO: Gigabyte Z77-D3H
My computer
HDD: 500GB Seagate
PSU: OCZ ZS 650W
