Solved
Getting ready to build first PC, have parts selection, need advice
Hi, I'm a first time builder. I am looking to build a gaming rig between $1000-$1300 with monitor, keyboard, and mouse. After mail in rebates, I am just squeaking under the $1300 mark.
I would like to know if all the parts I have selected are compatable with each other and will fit in the case selected. I've read up on everything and checked, but since this is my first time, I'm afraid I might be missing something that is obvious to the rest of you.
I am also looking for suggestions for alternative parts that may reduce the cost of the build, without neglecting too much quality.
Approximate Purchase Date: Before or on June 21, would like to start building June 30.
Budget Range: $1400 max before rebates, $1000 - $1300 after rebates
System Usage from Most to Least Important: Gaming, word processing (school), internetting (surfing/watching streaming video), watching HD movies
Parts Not Required: printer
Preferred Website(s) for Parts: newegg.com, tigerdirect.com, amazon.com (free shipping), microcenter.com (6% tax but still is sometimes cheaper with in store pickup)
Country of Origin: Maryland, United States
Parts Preferences: Intel, nVidia
Overclocking: Maybe in the future
SLI or Crossfire: Yes in the future
Monitor Resolution: 1920x1080
Parts list:
Mother Board: GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128502
CPU: Core i5 2500K
http://www.microcenter.com/single_product_results.phtml?product_id=0354589
GPU: PNY GeForce GTX 570
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133370
RAM: G.SKILL Ripjaws Series 8GB (2x4GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231402
PSU: PC Power and Cooling Silencer Mk II 950W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703028
HDD: Western Digital WD5002AALX Caviar Black Hard Drive - 500GB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7288041&sku=TSD-500AALX
Optical Drive: SAMSUNG Black 12X BD-ROM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151232
Case: CoolerMaster HAF912
http://www.microcenter.com/single_product_results.phtml?product_id=0343331
Monitor: ASUS VH242H Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236052
Keyboard & Mouse:Logitech 920-002565 MK120 Keyboard and Mouse Combo
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6420859&sku=L23-0083
OS: Microsoft Windows 7 Home Premium SP1 64-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
(Edit: updated RAM, ask for help format)
6 answers Last reply Best Answer
More about getting ready build parts selection advice
  1. Best answer
    Everything fits and everything works .
    You can save a little money though , if you want .
    You dont need a 950 watt psu
    650 watt would be plenty for that build
    The Ram you have chosen looks good but is only average quality . If you look at the details you see the timings are 9-9-9-24 . RAM is better with LOWER timings
    I'll look at other RAM.
    I'm going with the 950W psu because I think I'll want to SLI in the future when I have more money. It also ends up being cheap after mail in rebates and promotions. I've read that 750W should be able to SLI 2 GTX 570s, but the $110 after all rebates on the 950W is comparable to some 750W psus. Also, the deadline for the mail in rebate on the 950W psu is coming in a couple days, so I may end up pulling the trigger on that part fairly soon.
  3. Update:
    RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB)
    According to intel.com, the i5 2500k supports DDR 1333/1066, not 1600. That could have been a boo boo no? The timing on the new RAM is 7-7-7-21.
    *Edit*
    I just found Ripjaws series 8GB (2x4GB) DDR3 1333 with timing of 9-9-9-24 for $30 less, but I would have to order today. Would that be worth getting?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
  4. Meetho said:
    Update:
    *Edit*
    the ripjaw ram is what I'm considering buying with my build. seems like a good deal/decent component. Ram is basicly ram right?
  5. I'm using a i5 2500k and 8 gigs of G skill ripjaws x 1600 ram :D
  6. Best answer selected by Meetho.
Build Systems Product
