This 5-in-1 Laser MFC combines speed, performance, connectivity and reliability at a price that certainly fits any budget.
The MFC-4800 is a full-feature fax a 600 x 600 dpi, up to 10ppm laser printer. Convenience copying with multi-copying, reduction/enlargement from 50-200%, a 1200 x 1200 dpi (interpolated) resolution scanner that’s bundled with ScanSoftTM PaperPort® and TextBridge® OCR software and PC Fax capabilities that allows you to send and broadcast faxes directly from your PC.
Features
Fast, up to 10 ppm Laser printing
2MB Dual Access Memory with Quick-Scan
14.4K bps High Speed Fax Modem
Multi-Copying (up to 99) with enlargement and reduction
20 page Auto Document Feed
200 Sheet Paper Capacity
Broadcasting (up to 150 locations)
Navigation keys for menus, options and index dialing
Detail Features
PLAIN PAPER FAX
14.4K bps high speed fax modem
Navigation keys for simplified movement through menus, program options and auto dial index
Dual Access and Quick Scan (as fast as 3.5 seconds per page)
Stores up to 90* pages for out of paper reception
100 station auto dialing
64 shade gray scale
Error Correction Mode (ECM)
Automatic Fax/Tel switch
Call Waiting/Caller ID and Distinctive Ring Detection ready with local phone company service subscription
LASER PRINTER
True 600 x 600 dpi laser output
Up to 10 ppm print speed
Windows® 95, 98/98SE, Me, 2000 Professional, NT® Workstation 4.0, XP, Mac OS 8.5-X v.10/10.0
Parallel and USB interfaces standard (cables not included)
Straight paper path design
EPA energy star compliant with power saving sleep mode
Starter toner cartridge included (1,000 pages at 5% coverage)
COPIER
Crisp laser copy quality at up 10 copies per minute
Photo mode copying
Multi-copying up to 99 copies with sorting
Copy reduction and enlargement from 50%-200% in 1% increments
SCANNER
1200 x 1200 dpi (interpolated) scanning into your PC^ (max. 600x600dpi scanning with Windows® XP)
256 shade gray scale for photo resolution
One-touch dedicated key for scanning to e-mail, image or OCR applications^^
Includes award winning ScanSoft™ PaperPort® and TextBridge® OCR (these functions are not available for Windows® XP)
Works with Windows® 95, 98/98SE, Me, 2000 Professional, NT® Workstation 4.0, XP, Mac OS 8.6-9.2
PC FAX
Enables PC Fax Sending from your PC
Allows faxing from your PC
Fax Broadcasting from your PC
Works with Windows®/iMac™/iBook™/G3/G4
Contents
MFC-4800 Laser Multi-Function Center
Quick Set Up Guide
Owner's Manual
Multi-Function Link Pro Suite
Brother PC-FAX Driver
ScanSoft™ TextBridge® OCR
Starter Toner Cartridge (up to 1000 pages @ 5% coverage)
Drum Unit (DR-250)
<P ID="edit"><FONT SIZE=-1><EM>Edited by grayson73 on 10/25/04 11:18 AM.</EM></FONT></P>
