New HDD problem
I added a new HDD to my homebuilt system and installed Windows XP on it. Now i am getting some strange results, when i first start up the computer i get a long single beep and it refuses to start. If i then shut it down and take the Sata lead out and reinsert it the computer starts with no problem and then runs fine all the time it is on. There are no obvious problems apart from windows update being broken.
Anybody any idea what the problem is?
My setup
My system specs:
Processor Manufacturer: AMD
Processor Type: Athlon II 2 X 250
Motherboard : Gigabyte GA-MA770-UD3
Operating System Windows XP Pro SP3
SATA HDD 500GB , 1000GB (Windows)
System RAM: 2Gb
Video Card Manufacturer: Nvidea
Video Card Model: GForce 8600 GT
Video Card RAM: 1GB
Video Card Driver Version: Latest Driver
Sound Realtek onboard Latest Driver
1 answer Last reply
More about problem
  1. The first thing that you should suspect is that the power supply is either faulty or under powered. Substitution of the power supply is the only reliable test.
Homebuilt Graphics Cards Hard Drives Windows XP Systems
