try pressing Ctrl+Alt+delete and look through the running pro grammes list for anything unusual...
I wud say get Malwarebytes from www.filehippo.com and run a full scan....if you havent asked for it to happen it maybe spyware/malware..if you have been careless and installed some lame program the get Ccleaner from www.filehippo.com install and use it to uninstall programs and remove startup entries, but Malware bytes will kill most startup programs that will do you harm..
good PC housecleaning will stop things like this happening!
