Hi everyone,
I have never built a computer before and am stuck on trying to figure out the “right” motherboard for my build. I don’t think I need all the bells and whistles. I have no plans to OC right now as I’m new to it and don’t think the i5-3570k should have any issues running games at high settings (if I’m mistaken, please let me know). What MoBos would be a good choice for me? Here are two I’m currently torn between.
BIOSTAR TZ77XE3 LGA http://www.newegg.com/Product/Product.aspx?Item=N82E16813138355
ASRock Z77 Extreme4 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
ASRock seems popular, but has quite a few negative reviews and QC issues. Biostar seems to not only be cheaper, but also has better reviews? Which would you pick and why?
My core build:
Intel Core i5-3570K Ivy Bridge 3.4GHz
Cooler Master Hyper 212 EVO
Mother Board - unknown
G.Skill Ripjaws 8GB DDR3 1600
Corsair Silver HX750
Crucial M4 SSD 256GB
Cooler Master HAF 932
With extras:
Rosewill Wirelss Adapter 3 antenna
Arctic Silver 5 Thermal Compound - OEM
Lite-On iHAS124-04 24x DVD Burner
Windows 7 OEM
Thanks for your help!
My core build:
With extras:
Windows 7 OEM
