Solved
460 making high pitched noise under load?
April 2, 2011 4:12:30 PM
My gtx 460 (in my sig) started making a high pitched noise along with a rapid ticking noise. It's not real loud but it's very annoying. It's not the fan, I can adjust it anywhere from 0-100% in Afterburner at 2d clocks and it sounds fine. It only makes the noise when it is in 3d mode AND is displaying something on the screen. The fan speed doesn't affect it. I can't rma it because I reapplied my own thermal paste to drop the temps and flashed it to remove the voltage cap. Any ideas what could be making the noise or how to fix it?
Best solution
a c 173 U Graphics card
April 2, 2011 4:58:54 PM
You could try to contact customer service to see if they would. That ticking noise is likely the fan as coil squeal is a very different nose rather than a ticking noise. Check for lose wires or cables that are in the way.
December 10, 2011 10:51:26 AM
My gtx 550 ti makes the same sound when I start a game..
its not from the cooler..
@Andon48 our problem is not anyone can hear this sound I think because its on a very high frequency:)
m
l
June 13, 2012 4:45:04 PM
Best answer selected by Andon48.
m
l
