Solved
Cooler Master PSU with 20+4 cable connector issue
  • Power Supplies
  • Cooler Master
  • Cable
  • Motherboards
  • CPUs
  • Components
Last response: in Components
September 10, 2011 7:47:24 PM
Hi all,
I have a gigabyte motherboard and a Cooler Master Silent Pro 500w. The mobo has a 24 pin connector and I can get the 20 pin part plugged in and then the extra 4 pins won't fit because of tiny plastic pieces coming off of it (picture attached). There's the additional 12v for the CPU too. So am I only supposed to use the 20 pin + the cpu or should I shove the other plug in above the 20, but it doesn't fit all the way?
Thanks!
More about : cooler master psu cable connector issue
Best solution
a c 298 ) Power supply
a b V Motherboard
a c 231 à CPUs
September 10, 2011 7:48:54 PM
The 4 pin should lock into the side of the 20 pin connector, do that before putting it in the slot and it should lock into place as a single 24 pin connector.
September 10, 2011 7:56:52 PM
hunter315, you're awesome! Common sense is not with me today as I just frustrated myself for a half hour on this issue. Thanks!
m
l
September 10, 2011 7:57:03 PM
Best answer selected by cdr86.
m
l
