Closed Solved
Help with picking a motherboard
Hey guys, I had my computer build completely picked out but I thought I should upgrade my mother board which one should I get? Also, I want to spend about $100-$150 on the motherboard.
Here's my build-
Case- COOLER MASTER HAF 922 RC-922M-KKN1-GP http://www.frys.com/search?search_type=regular&sqxts=1&query_string=HAF+922+&submit.x=20&submit.y=10&cat=0
Processor- AMD FX-6100 Zambezi 3.3GHz Socket AM3+ 95W Six-Core Desktop Processor FD6100WMGUSBX http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
Graphics Card- EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
Hard Drive- Western Digital Caviar Green WD10EARX 1TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136939
SSD- OCZ Solid 3 SLD3-25SAT3-60G 2.5" 60GB SATA III MLC http://www.newegg.com/Product/Product.aspx?Item=N82E16820227728
RAM- Patriot Gamer 2 Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PGD38G1600ELK http://www.newegg.com/Product/Product.aspx?Item=N82E16820220558
Power Supply- RAIDMAX Blackstone series RX-700AC 700W Continuous Power ATX12V V2.3 / EPS12V V2.91 80 PLUS BRONZE Certified Modular Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817152042
Thanks :wahoo:
4 answers Last reply Best Answer
More about help picking motherboard
  1. A good mid-range board that I like to recommend to AMD people is this. It has all the bells a whistles, and is very durable:
    GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
  2. Best answer
    +1^
    A nice $100 board.
    If you are going to be gaming at resolutions above 1680x1050, I would recommend a step up in your graphics card choice, though.
    I'm glad to see you wil be relying on a SSD for your main drive. The green drives are a tad slower than regular drives (5400rpm vs 7200rpm). And some of them have the nasty habit of going into sleep mode.
  3. Best answer selected by Jake4697.
  4. This topic has been closed by Nikorr
Motherboards Product
