I'm buying a new system and so far it looks as follows: A cooler master midtower case the RC-p100k-KWN2 With windowed side-panel, 4x coolermaster extraflow fans, the v6 CPU cooler, core i5 2500k, a GIGABYTE GA-Z68X-UD3P-B3 motherboard, 2x4gb patriot viper extreme division 2 memory, a TB of hdd space and two gigabye overclocked edition radeon 6870's. They have three fans each so temperature is not one of my concerns. I am however worried about my power requirements. My options are a 750w gx from coolermaster or their silent pro gold 800w. Please note that I wish to overclock and my main concern is whether my power will remain stable and if my system can handle overclocking (worst case scenario) without the psu shitting on the load. Secondly I wish to know if the motherboard supports crossfire( I believe it does, but I need to make sure) and if the two gigabytes are a good choice.(Not the 6870's, I'm going with em, but the oc gigabyte editions.) Will my power hold, will my rig work to play most games, is all my hardware compatible and what will my oc options be with my power supplies.I would also appreciate a few links and a minimum system power requirement for my rig.Please answer all my questions fully, and I thank you all in advance.
