Thanks in advance to any who can help and apologies if I am doing this wrong. I was amazed when I saw this site as, if you can review my intended purchase and give advice, it will mean a ton to me. It sounds to good to be true. Anyway, it is time for a new family PC, multimedia I guess (music, blu-ray movies, and stored home movies and pictures, plus expert use of excel/access db for my work). I went to a local store for a quote and here is what they came up with. Main questions are:
1) What do you think? any changes?
2) I would like to connect it to my harmon kardon receiver and polk speakers, should I get a sound card?
3) Do you think I, with OK experience with PCs but never having built one, could try to build myself (as they are just buying parts from NewEgg and charging $500)
Here is what they recommend (my budget is around $2000 - I know it is probably overkill, but it has been a LOOONG time since I have had a new PC and I need this one to last a looong time):
Optical Drive:
LG Black 10X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model UH12LS28
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
Case:
Antec Lanboy air Blue Black / Blue ATX Mid Tower Computer Modular Case
Hard Drive Primary:
Seagate Barracuda XT ST32000641AS 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
OR
($200 more) Hard Drive Primary:
Western Digital VelociRaptor WD4500HLHX 450GB 10000 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
Video Card:
EVGA GeForce GTX 560 Ti (Fermi) Maximum Graphics Edition Crysis 2 1GB 256-bit GDDR5 PCI Express 2.0 x16
Power Supply:
Rosewill Xtreme Series RX750-S-B 750W 80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready
Memory:
CORSAIR Vengeance 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Motherboard:
ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Processor:
Intel Core i7-960 Bloomfield 3.2GHz LGA 1366 130W Quad-Core Desktop Processor
Operating System:
Microsoft Windows 7 Home Premium 64-bit
Wifi Card:
Rosewill RNX-N300X PCI Wireless Adapter
Sub-Total: $ 1947.98
Tax: $ 163.14
Total: $ 2111.12 (or $2300 with extra HD memory/second internal drive)
2 year warranty on labor
Manufactures warranty applies
Free Data Transfer
Full Initial software set up
1 Yr Free On-line Support
THank you SO SO SO much.
RIchard
Optical Drive:
Case:
Hard Drive Primary:
OR
Video Card:
Power Supply:
Memory:
Motherboard:
Processor:
Operating System:
Wifi Card:
Tax: $ 163.14
Free Data Transfer
RIchard
