Hello,
I just bought Radeon 4670 to replace my Radeon 1650 XT..for a time everything seems to be okay, but then the problem occured.
My monitor sometimes (suddenly) turns off..everything else seems to be okay, my processor still running, VGA's Fan also running..only the monitor turns off and there's some buzzing sound out of the speaker..
the Symptoms quite random..sometimes I can use may computer normally, sometimes I use it for an hour or two and suddenly it turned off..
What Happen ? Please help Me
Here is my Spec :
- AMD Athlon 64 X2 +4800
- 4 GB RAM
- Win 7 Os
- PSU Acbel 470 Watt
- I'm still using a CRT monitor
Here is my Spec :
- 4 GB RAM
- Win 7 Os
