Major7up said:
While luiscloss makes many valid points, I found relatively inexpensive CAT6 stuff at monoprice.com and wired my whole house with CAT6 rather than CAT5e. I did this because I wanted to future proof my home. While CAT5e may allow gigabit communication, when 10 or 100Gb comes around it may not support this. At monoprice, 1000 feet of CAT5e UTP rated at 350MHz is around $65 while CAT6 rated at 550MHz is just under $100. This should be a consideration as CAT5e may be fine now but what about later down the road?
* * * VERY IMPORTANT * * *
Whichever cabling you go with there is an important bit luiscloss forgot to mention: Make sure you buy the appropriate fittings
for the type of cable you buy. Even in CAT5e or CAT6 there are solid core cables and stranded cables. Each requires different fittings so make sure you by the right kind. And though it is not necessary, boots (those little covers that bridge the area between the connector and the cable) are good to have also.
Major,
Thanks for your reply. Its always pretty to receive some good comments.
But do not forget, this was on my original email:
The cables are completely different. Different wire sizes, different reinforcement, cat6 has an internal "septo" which leads all 4 pairs totally separetad and
OF COURSE, you can´t plug or insert a cat6 cable into a cat5 connector. Why: it does not fit!
Also, it is more than obvious that cables are getting cheaper and cheaper. Thats true! I personally dont like the prices here in Brazil. If you pick your example, we are talking about 40% price difference. It may not be very much for small instalations, but really expensive when talking about big project.
In fact, I do agree that when we will start (hopefully soon) to have 10GB and 100GB speeds the cables might be a problem. But dont forget to mention that today in most cases the bottleneck will be harddrive access time or machines internal bus speed. I personally dont like the boots, just because it makes difficult to manipulate the cables on patch panels (but you will not manipulate much anyway!).
Well, I still would go with cat5 and have that dinner! Take into consideration that most applications will be wireless in a near future, since this is also a tendency. Dont forget this!!! Today its not very fast, even running 802.11n.
Bye. Have fun. Cable or Dinner, its up to you!
