Ok so i have "some" IT experience, mostly home-use and some business too. Ive replaced hardware components of existing machines but have never really done any "upgrades" other than adding some RAM. Building a PC myself will save me a good £200+ from the shelf price and i feel i can get a much better build. I have had a look round the web and sourced a build to fit my needs and budget. As far as im aware all the components will work together without any issues.
Asus P8P67 LE R3 P67 Socket 1155 £105
Intel Core i5 2500K 3.3GHz Socket 1155 £160
Corsair Vengeance 8GB (2x4GB) DDR3 1600Mhz £82
Arctic Cooling Freezer 13 Pro £20
Coolermaster GX 650W PSU £61
Asus GTX 560Ti DirectCU II 1GB GDDR5 £179
Samsung HD103SJ Spinpoint F3 1TB Hard Drive £42
Sony Optiarc AD-5260S 24x DVD±RW £15
Casecom 6788 Black Mid Tower Case £29
If anyone has any suggestions for different parts (on a £700-ISH budget). The build above comes to about £690 however i will probably buy another fan for the case since its only supplied with 1, thus totaling about £700.
Any suggestions or advice will be much appreciated. Many thanks in advance.
