Hi yall, I'm pretty new here and recently scrapped an overly expensive Cyberpower PC that I had customized and now have about $1200 to work with, though I'd like to stay in the $1000-$1150 range if possible. I intend to use this system for MMO gaming tailored more to games like EVE Online and the upcoming Old Republic as well as use it for 3D rendering in Maya and AutoCad. I don't need something that is going to burn my pubes off with speed, but I'd like a good system I can use for these applications for the next several years. I'm buying everything from Newegg because I've used them before and think they are very reliable and have great prices/rebates/offers. This is my first time building a PC and I feel like I've researched extensively on these components but I lack the expertise and general knowledge about computer building to know for sure how if everything fits together/compatible or if the PSU is enough wattage. Okay so here we go and thanks for commenting -NOTE: I listed the Newegg prices too, they're not part of the urls
MOBO: ASUS Sabertooth X58 LGA 1366
http://www.newegg.com/Product/Product.aspx?Item=13-131-665&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=1&VideoOnlyMark=true&VendorMark=&IsFeedbackTab=true&SelectedRating1=1&chkVideoOnlyMark=on&Keywords=%2528keywords%2529&Page=1%23scrollFullInfo $200
CPU: I5-2500k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&cm_re=i5_2500k-_-19-115-072-_-Product $220
PSU:CORSAIR Enthusiast Series CMPSU-650TX 650W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005&cm_re=corsair_650-_-17-139-005-_-Product $85
GPU: HIS ICEq Radeon 6870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161369&cm_re=HIS_iceq_6870-_-14-161-369-_-Product$180
RAM:CORSAIR Vengeance 8GB (2 x 4GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345&cm_re=2x4gb-_-20-145-345-_-Product $85
Fan: Thermaltake V1
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106102&Tpk=Thermaltake%20V1 $50
Case: CoolerMaster HAF 912
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 $60
SSD: Crucial M4 CT064M4SSD2 64GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441 $120
HDD: Suggestions?
I think that's all I've got for now, thanks for your help!
CPU: I5-2500k
Fan: Thermaltake V1
HDD: Suggestions?
