Looking to you guys for help. I have an HP XW4200. It curently has a standard 400 watt power supply, Pentium 4 3.8GIG procerssor (dual core), 4 gig of RAM, and an nVidia 9600GT with 2 GIG RAM on Windows XP. So far it has been runnign quite well. No overheating and the 400 watt power supply has been adequate. However, I would like to up the wattage in the power supply so I can take advantage of newer, more powerful video cards. Here's the problem. The power supply in the comp is a "proprietary power suppy. So I can't just order any old power supply and bolt it in. HP did make an "upgrade kit" of a 500 watt power supply. The part number is PK746A. That is what I would like to find. I searched but haven't been able to locate one. I use the computer mainly for gaming. It has been more than adequate so far. I just wanted to up it's abiities so I can run a more capable graphics card. My money tree died last year so I am NOT able to buy a whole new comp just to play games :lol:
Absolute last resort is trying to find a power supply that would fit in the case and have higher wattage. I would most likely have to drill new mounting holes as the current power supply doesn't use the same bolt pattern as new ones. Also not sure whether the connections would all be there.
Also, the current power supply uses a 24 Pin connector. Not sure what that means
Dep
Dep
