What kind of pci card do I need to use audio vidio hdmi from my PC to a monitor?
  • Graphics Cards
  • PCI
  • Audio
  • Monitors
  • HDMI
  • Graphics
April 4, 2011 10:53:26 PM
Hello,
What kind of pci card do I need to use audio vidio hdmi from my PC to my monitor? I would also like to have a TV tuner.
More about : kind pci card audio vidio hdmi monitor
April 5, 2011 1:12:20 AM
Quote:
Are this for media centre purposes?
What's your budget and your native resolution?
I have a Pentium(R) 4 CPU 3.20GHz, 3.00 GB of RAM, on a MSI 875P motherboard that has 5 32-bit v3.2 Master SCI bus slot.
m
l
April 5, 2011 1:33:40 AM
Quote:
That board can take Agp X8/x4. What are you currently using. Integrated graphics?
You can add a tv tuner and then still signal it thru to your monitor via your current connection. But that cpu might be holding you back. I know the 4850 1gb version is the best and think last Agp card released
I am currently using a Tirdent Vidio accelerator 3D Image 975.
m
l
April 5, 2011 1:43:20 AM
Thanks for the help.
m
l
April 5, 2011 5:32:45 AM
Thanks I am planning to upgrade.
m
l
