Help With CCC Overclocking please help
Ok i dont think people understand theres a thing called AMD overdrive and theres a section where it says current gpu and current memory clock values its mesausered in Mhz not i set my GPU clock setting to max and my Memory clock settings to max but when i look back down at my current settings nothing is changed
Gamer-girl said:
did you click apply at the bottom right corner?
yep i did but when i did that the current values didnt change do you think or do you know how i can configure the CFG file to allow you to bypass ATi's driver clock speed limits
Ask the community
