Monitor and/or GPU problems,help needed.
Hey all,
I am experiencing a problem but I am not sure what causes it.
Everything was going fine until my monitor (Samsung 226BW S panel)started acting strange,it was getting flickering lines and boxes all over the monitor.After a quick search I found out about the bad capacitors on this monitor,so I opened it,changed one of them who seemed bad but the problem was still there.
I have also tried a different DVI cable,and I plugged in an old CRT with a VGA to DVI adapter and a LCD TV with a VGA to DVI adapter as well as a HDMI to DVI cable.These were working fine,in the same time my monitor was still acting strange.
Can someone tell me what can be causing this problem?It's driving me crazy not knowing where the problem is.
Here's my specs (no hardware/software changes for quite some time)
Q6600 OC'ed to 3.2 watercooled
8800GTX stock
4GB RAM
Abit IP-35 PRO
Thanks.
10 answers Last reply
More about monitor problems help needed
  1. first look the properties graphic card an check (vertical) v-sync is on...second look the refresh rate to check auto and look the rerfresh rate to your monitor suport hz.
    Everything is normal.
  3. Is it safe to assume that the GPU is fine since I have already plugged in a CRT and a LCD TV with no problems?
  4. look behind to the monitor or graphic card to something gone wrong...pins cable, etc.or try a new cable if i have.also download tis aplication and test
    http://www.passmark.com/products/monitortest.htm
  5. All connections are fine and I have already tried a different DVI cable.
  6. what is happens my friend ??????......all ok finally?
  7. Nope,tried everything,nothing works :(
  8. .....check to the end another anyone old graphic card...in order to we see the problem monitor or graphic card.....and tell me,...curious i I have same monitor samsung almost 3 years and it has not presented to me nothing
    (syncmaster T260)...it looked at you have near , speakers, subwofer, mobile phone etc. and influence the pc
    finally search the guarantee maybe its monitor problem and back to the shop :(
  9. Any other suggestions?
  10. tryied eyrything my friend.......rather it has problem monitor… it behind went in the shop that you bought him to you him they change
Graphics Cards DVI Monitors Graphics
