Motherboard overheating plz help
  • Motherboards
June 3, 2012 1:10:38 AM
I recently noticed my pc was getting hot. i checked speccy and saw my motherboard was over 80 degrees. heres my specs. any help would be appreciated. i have 1 case fan, the cpu fan and the power supply and they are all working fine.
Operating System
MS Windows 7 Home Premium 64-bit SP1
CPU
Intel Core i7 920 @ 2.67GHz 58 °C
Bloomfield 45nm Technology
RAM
4.00 GB Triple-Channel DDR3 @ 531MHz (7-7-7-20)
Motherboard
Dell Inc. 0R849J (CPU 1) 83 °C
Graphics
DELL S2009W (1600x900@60Hz)
ATI Radeon HD 4800 Series (Dell) 71 °C
Hard Drives
488GB SAMSUNG SAMSUNG HD502IJ ATA Device (SATA) 31 °C
Optical Drives
WXK S5274TEZO1 SCSI CdRom Device
HL-DT-ST DVD+-RW GH30N ATA Device
Audio
Realtek High Definition Audio
More about : motherboard overheating plz
a c 490 V Motherboard
June 3, 2012 2:06:19 AM
if it a case flow issue open the side panel. if the temps drop it an airflow issue. with the cpu and gpu temps check to see if the fans are connected to the right header and the set up of the fan speed in bios. you may need to turn up the fan speed profile or use a program that lets you make one.
m
l
June 3, 2012 8:56:00 AM
thanks alot, ima try to set up a profile for it
m
l
a b V Motherboard
June 3, 2012 11:53:00 AM
If it is ideal temp for your system, then it is high. You need a better cooling system with intake and exhaust fan in pc case. And open side panel as posted above.
m
l
