First Build - Cabinet and Power Supply
Hello Guys,
I am building a new system for casual gaming, and here is the config.
Gigabyte GA-880GM-USB3 Motherboard
AMD Phenom II X4 955 Black Edition Processor
GSkill RipJaw 4GB DDR3 1600MHZ
ATI Radeon 6750 1GB DDR5
Which cabinet & power supply would you guys suggest
i was looking at Cooler Master Elite 430 Black Transparent PC Cabinet & Cooler Master eXtreme V2.3 460W RS-460-PCARA3 Power Suppl. Would the power supply be sufficient.
And pls let me know if there are any other better video cards than 6750 that are available. My budget is around 6,000 INR (India) for the graphics card.
Any other suggestions would be helpful as I am building my first Pc :) Appreciate any help!
1 answer Last reply
More about first build cabinet power supply
  1. I suggest a Corsair or Antec power supply over coolmaster. Also I suggest a better graphics card even if you have to get a cheaper Athlon CPU. I consider a 5770/6770 the lowest proper gaming card and a 6850 is alot better. Get a good 500W+ power supply for a 6850 though.
Power Supplies Components
