New build help
Approximate Purchase Date: 1 month(ish)
Budget Range: Around £600
System Usage from Most to Least Important: Gaming,Gaming and more GAMING
Parts Not Required: Keyboard,Monitor,Mouse,Speakers.
Preferred Website(s) for Parts: Any trusted UK Based Website
Country of Origin: UK
Parts Preferences: Big case, lots of fans
Overclocking: Maybe
SLI or Crossfire: Probably Not
Monitor Resolution: 1366 x 768
Additional Comments: I will be playing games like css,WoW,empire total war and some other source games + I'm not builidng the pc, my dads getting somone to make me a computer so i was going to pass these specs on to him + please remember to include OS :)
11 answers Last reply
More about build help
  1. Look at set up here:
    http://www.tomshardware.com/forum/312822-31-bestconfigs-budget-intel-based-gaming
    http://www.tomshardware.com/forum/312823-31-bestconfigs-budget-based-gaming
    to get ideas. Also try the tom's hardware system builder app.
    http://www.facebook.com/apps/application.php?id=174382929259516
    After you think you have a good set up, post spec back so we can give you advice.
  2. It's not working for me :(
  3. I called for help from UK forum members. They will provide you with better advice about your build. Sorry that I couldn't give you a build myself because once I start building I realize the price in Australia is very different than in UK.
  4. Okay, thanks :)
  5. AMD Phenom II X4 965 £105
    http://www.ebuyer.com/product/186428
    Asus M4A87TD/USB3 £69
    http://www.ebuyer.com/product/206152
    Asus HD 6870 Direct CU 1GB GDDR5 £152
    http://www.ebuyer.com/product/254404
    G-Skill 4GB (2x2GB) DDR3 1600mhz Ripjaws Memory Kit CL9 (9-9-9-24) 1.5V £34
    http://www.ebuyer.com/product/240501
    Samsung HD103SJ Spinpoint F3 1TB £42
    http://www.ebuyer.com/product/173804
    Cooler Master HAF 922 £76
    http://www.ebuyer.com/product/164961
    Antec High Current Gamer HCG-520 80Plus Bronze £52
    http://www.ebuyer.com/product/245671
    LiteOn iHAS224 £15
    http://www.ebuyer.com/product/190838
    Windows 7 64bit Home Premium £67
    http://www.ebuyer.com/product/173791
    Total: £612
  6. Above build is very good, only change is to swap the Optical Drive to the Sony Optaric:
    http://www.ebuyer.com/product/220986
    Don't want all that white writing on the front of your case :D
  7. Thanks guys:) + will that 6870 run games like wow and css with max graphics and good fps?
  8. lol the 6870 will run crysis at a decent rate
    asking if it can run Css or WoW is an insult to the 6870
  9. oooo sounds good:)
  10. I won't be getting a computer for a month but i will defiantly bookmark this! :D
New Build Systems
