First time I went to use the eithernet port connect to my mobo.. I keep getting network cable unplugged so I have decided to buy a cheap network card. Here is what im looking at..
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100010064%204024&IsNodeId=1&name=%240%20-%20%2410
My concern is that I have installed ram, audio and video cards into my computers before but never anything that didn't exactly fit the slot its meant for. Will any of those work for my computer? If so, I wont need to connect power to it right?
Windows 7 Ultimate 64 bit
Core 2 Duo E7400
2 GB Ram
PCI E 1.0
Core 2 Duo E7400
2 GB Ram
PCI E 1.0
