well if it is up and running it should be enabled already, AFAIK there's no way to disable 3d properties of a gpu and only use the 2d 'part' if the drivers are installed...
google search didnt find anything usefull with that model number, so what exactly is that thing? a laptop? how old?
All on-board stuff is really slow anyways, so that might be the reason you think it is disabled...
