I've been looking into getting a fan controller but im not really sure on the specifics if anyone can help me out. First, does it get the temperature reading from the motherboard or are there external sensors or sensors on the controller. Second, does the controller plug into a normal fan plug on the motherboard and if so wouldn't it be a problem when the motherboard turned down the fan voltage which turned down the voltage to the controller? I've been thinking of getting this one unless anyone knows of a better one that's not to expensive.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992005
Thanks.
Thanks.
