all of a sudden today my monitor has a very green tint. I was online and i thought it was just the website i was on but it wasn't. Its a 2-1/2 yr old 19" EV910 came with my Gateway Performance 700 Mhz system. My video card is only 2 months old. Gainward GeForce 3 Ti200. How do i tell if its the monitor or vid card or other? A couple times its gone back to normal for about a minute then goes green again
Sponsored Links
ok ok first thing to try is
MAKE SURE IT IS PLUGED IN REAL GOOD TO THE PC.
i had a similar problem and it was because the case and vid card connector were so close that i couldn't fit in the plug well.
so i wiggled it and the colour problem was solved.
symptoms
loses one colour
flickers on/off losing this colour.
eventually it filckered off for ever
untill i wiggled the plugs!!!
:p :p
hope that is the problem!!!!!!
Reply to alltaken
Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Monitor problem
There are 759 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
