Solved
Power consumption for asus gtx560 TI
Last response: in Components
Best solution
Power supply Authority
Actually 500W very very enough ... but that 's 500 Watts eXtreme Power Plus dangeorus for system and 9800GT because actually 460W efficiency 77% with labelled 500W / 600W ... yea , for better get from good brand antec, seasonic, corsair, xfx etc with same power watt 500 very very enough.
and it's al depend your budget , of course .. see price and performance from good reviewer like jonyguru,hardwaresecreet, Kitguru, Harocp
Antec EarthWatts 500 W :
http://www.hardwaresecrets.com/article/Antec-EarthWatts...
OCZ ModXStream Pro 500 W Power Supply :
http://www.hardwaresecrets.com/article/OCZ-ModXStream-P...
Related ressources
You may also wish to pay your RAM some attention as you say you have 6gb ?
You should have 4 ram slots and all 4 slots should be filled with equal amounts of ram for system stability, E.G.
4 x 1gb =4gb
2 x 2gb =4gb
4 x 2gb =8gb
4 x 4gb =16gb
4 x 1gb =4gb
2 x 2gb =4gb
4 x 2gb =8gb
4 x 4gb =16gb
so its better to change my 2 gb slot to 4 gb to balance up..?
Ask the community
