Can you overclock ram more than its rated speed
Can you overclock a Ram that is over it's rated speed like for example this: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
It is rated at 1600, Can I overclock it to 1866mhz or 2000mhz?
2 answers Last reply
More about overclock rated speed
  1. To some extent (1866), yes, probably, but there's no real reason to. 1600 is plenty for anything but bench runs.
  2. It is doable but not recommended because usually you have to adjust the timings so you loose the benefit of the increased speed.
Memory Overclocking RAM
