Finalizing on Parts for a Performance PC - Need a Final Look
Hey after alot of research, i have came to a conclusion list of parts. Just want a third opinion before i place the order
Purpose of PC: h264 enocding ( i will overclock it and use additional graphic cards if useful)
Budget: Its still flexible if i see a suggestion which would Help
Here is the List:
1) COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
2) SAPPHIRE 100311-2SR Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
3) Rosewill BRONZE Series RBR1000-M 1000W Continuous@40°C, 80Plus Bronze Certified,Modular Cable Design,Active PFC"Compatible ...
4) G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM
5) ASUS P8Z68 Deluxe LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
6) CORSAIR Hydro H70 CWCH70 120mm High Performance CPU Cooler
7) OCZ Agility 3 AGT3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
8) Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) 4 x 256KB L2 Cache 8MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor
1 answer Last reply
More about finalizing parts performance final look
  1. PSU - Overkill... With that combo a 650w would be plenty. If you are debating on adding a second HD 6970 down the road, then an 850w PSU would be the choice. Stick with Rosewill, Antec, Corsair or XFX...
    CPU Cooler - Water cooling just adds to the "cool factor" and won't do any better than a good CPU cooler that cools by air. The Hyper 212+ with two fans in a push / pull configuration is hard to beat at roughly $40.
    HD - Consider adding a secondary hard drive to that config for storage or application installation. The Samsung F3 1TB drive is $60 and a great performer. The 120GB SSD is great, but can fill up quickly.
    Enjoy that build! It should game nicely...
Homebuilt Systems
