Laptop home wireless connection
Hello,
I need help setting my laptop up to the wireless router. I found the network but when I entered my pass code the network could not find the router or network and now it has a red X on my wireless router network, I hooked it up like it said to in the instruction booklet that came with the service but it didn't work. I really need help, or a step by step instruction email to get my laptop going. Thank you Sheryl
1 answer Last reply
More about laptop home wireless connection
  1. Connect the computer to the router with an ethernet cable.
    See the literature which came with your router for how to access the user setup screens in the router. Once in go to wireless security and review or renew the wireless security type and password. WPA PSK TKIP is the most common security type in use. Make a note of the SSID or change it to one of your invention.
    Go to wireless mode and ensure that it's set to a protocol matching your computer's wireless adapter (mixed mode is a safe bet).
    Disconnect ethernet cable.
    Go to the computer's wireless networking setup screen and see if you can detect the router's SSID (wireless call sign). Select that network.
    Apply the wireless security type and password to the computer's wireless networking setup screen.
Routers Laptops Wireless Router Connection Networking
