I have a home built mid tower PC. It's use is for gaming, HD video editing and web development. I have lagging issues when running rFactor (HD racing game). And when doing large scale HD videos (5GB+) the PC chokes badly. I can't even publish my project files from Adobe Permier Elements, it says low on system memory. I've went to the extent of removing all AV software and cleaning up Windows but get the same results. Here's the problem child's specs:
ASUS M2N68-AM Motherboard
AMD Athlon X2 64 3.1 6000+ GHz dual core
GeForce 9600 GT 512MB GPU
4GB PC8000 DDR2 RAM
550W Power Supply
Main HDD 300GB IDE (no partitions)
2nd HDD 1 TB 7200 SATA2
XP SP3
After searching I think the 550W PS isn't enough power for the GPU and 2 HDD setup. I think the GPU and CPU are pretty decent based on reviews but AM2 socket is becoming old school already. And my board is lacking SATA ports if I expand so I'm debating on a new CPU/MB package. I was hoping for some input on whether the power supply should be swapped out first but this won't speed up video editing so a new build entirely may be in order. Should I retire this system for a new build or can this one be made up to par? Thanks in advance!
4GB PC8000 DDR2 RAM
550W Power Supply
XP SP3
