My specs are...
AMD Phenom II X4 970 Black Edition Deneb 3.5GHz
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
XFX HD-687A-ZNFC Radeon HD 6870 1GB 256-bit DDR5 PCI Express 2.1 x16 crossfire'd
Thermaltake TR2 RX 750W Bronze W0382RU ATX 12V
MSI 870A-G54 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
NZXT phantom case
So originally I had the cooler master elite 310, which is a mid tower and was hoping it was going to be okay for what I needed, even though I sort of knew it probably wouldn't I still got it. I had the ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD mobo as well.
So I had my computer put together, it was working great and all that stuff but then I noticed my temperatures about 2 weeks after putting it together. I decided to turn to water cooling. I bought the xspc rasa kit, 360 radiator, and 2 gpu waterblocks. I knew that I would have a hard time fitting everything in, so I made a riser thing for my case to sit on and I would put the radiator under it. I drilled holes in the side panel to feed the hoses through. I put it all together, I made it work I turned it on, nothing. The fans were spinning, I don't remember if there were lights on the motherboard or not but it wouldn't post, it was just sitting. I tried troubleshooting that but nothing worked. In my thread on the water cooling section posted this problem, people said it could have been the back plate since I was stupid and had the metal part on the mobo and may have shorted it. I figured that's what the problem was.
So I ordered a new case, the NZXT phantom and I went to frys to get a new motherboard, the one in my specs. Problem again! I was just putting it together the past few hours, I decide before I get too far into it to see if it will post, I turn it on with 1 gpu in, 2 sticks of ram and cpu. Lights turn on on the motherboard, I have a cpu fan plugged in to make sure it's working, nothing. Same thing as before, no post, nothing. I remove the gpu, try it again, nothing, I re-place the ram, nothing, I remove a stick, nothing. I have no idea what the problem is but I'm so tired of being on my laptop, this is so incredibly frustrating. I really need some help. I'm thinking about taking this to some PC place to get them to fix it but I'd really rather not, since I have some content on my HDDs that I don't want to be seen.
What can I do. It's really depressing me.
Thanks in advance.
NZXT phantom case
Thanks in advance.
