More Power?
Is this CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 PSU provide enough juice to comfortably power this setup?
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
1x 200mm Top Stock Fan
2x 120mm Front LED Stock Fans
1x 120mm Rear Stock Fan
ASUS P8P67 LE (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-2500K Sandy Bridge 3.3GHz
1x Small Fan and Heat Sink (but would like to upgrade)
EVGA SuperClocked 01G-P3-1563-AR GeForce GTX 560 Ti
G.SKILL Ripjaws X Series 8GB
Western Digital Caviar Blue WD10EALX 1TB 7200 RPM SATA
LG CD/DVD Burner Black SATA
Also while your here if you could please confirm for me that, that Nivida Graphics Card is compatibly with that Asus Intel motherboard that would be great too! :)
Thanks for your help!!!
PS Any other thoughts on the build are welcome, just let me know.
3 answers Last reply
More about more power
  1. Yeah it's more than enough. Build looks good :)
  2. Cool I just wanted to make sure I wasn't short. Do you think I'd still be okay upgrading the fans and adding maybe a water cooler for the CPU?
    Thanks for your help.
  3. Fans only draw a couple of Watts. By water cooler you mean something like the Corsair pre-assembled closed-loop ones? I don't think they draw too much power either.
Power Supplies Components
