Closed Solved
Problem with x58 extreme
I just built a computer with an asrock x58 extreme motherboard. The computer operates very well, but when I turn it on I have to press the power button two or three times really fast or it doesn't boot and the fans just start spinning. I've rule that this is probably a problem with the motherboard. Can someone tell me what the problem is and how I can fix it?
3 answers Last reply Best Answer
More about problem extreme
  1. Best answer
    Have you bread-boarded it and tried starting by shorting the two pins that the start button plugs into?
  2. Best answer selected by lt_dan_zsu.
  3. This topic has been closed by Nikorr
ASRock Computer Motherboards
