Q code 76 DRAM_LED
Hello,
I would much appreciate any help anyone can offer as i have decided to try my first personal computer build and have run into trouble. I have tried the first boot of my build and have recieved a q-code 76 on the motherboard with the DRAM_LED lit up. I have refered to the Asus motherboard manual which doesn't give information to fixing the issue. It only tells me that q76 is (initializing PCH). I am not sure what this means. Any suggestions on a fix for this q-code would be much apreciated.
Thank You
Specs At the Moment:
Asus Maximus Gene-z z77 Motherboard.
Intel i7 3770k
8gb corsair vengence ddr3 ram @1600mhz
Ocz ZT 750w PSU
Samsung 64gb ssd
(Graphics not yet purchased)
1 answer Last reply
More about code dram_led
  1. Frozn Gamer said:
    Hello,
    Thank You
    Intel i7 3770k
    Ocz ZT 750w PSU
    Samsung 64gb ssd
    Any luck with this? The same thing happened to me on a Maximus Gene V board.
    Tried pulling the ram out, re-seating cpu, disconnecting all peripherals... nothing worked.
Chipsets Motherboards LED Monitor
