Hey Guys, I wanted a general advice about the new PC i am going to assemble to see if it is going to be stable and compatible. Please advice which are better options to choose:
The system specs are as below:
Intel i7 [3.2GhZ] or i5 [3.2 Ghz]
i will use i5 [3.2 ghZ] , as i7 is good but the motherboard i found which is Intel DX 58SO , is out of my budget.
If i use i7 (is Intel H55-TC good motherboard to support i7) or should i just stick with i5?
If i use i5 [3.2 Ghz] which motherboard will support the best out of these:
1. Gigabyte 58XUD3
2. Intel H55-TC
3. Gigabyte H55M-D2h
4. Gigabyte GA-P55-UD3L
then this:
8 GB DDR3 ( 4 + 4) RAM
1 TB Western Digital Hard Drive
LG DVD+- RW
Graphic Card NviDia Geforce EvGa 210 [1GB] or Geforce GT 430 [1 GB] ?
Gigabyte X2 or X6 Case ? (Is it going to have enough power to run everything smoothly and will it be cool enough ?
I am planning to use this as for general home HTPC and CAD softwares.
Should i go with ATi ? Does it have a good interface now to clone screens onto HDTV? I have one card which is an alternative to Geforce, which is ATi 5750! is that good?
Please advice, thanks
Please give suggestions.
Thanks to everyone,
Yours sincerely,
UAR.
1. Gigabyte 58XUD3
2. Intel H55-TC
then this:
LG DVD+- RW
Thanks to everyone,
Yours sincerely,
UAR.
