I just received my new custom build using a Asus z68 V-Pro. i7 -2600k, and Kingston HyperX Blue RAM with a Scythe Mugen 3 cooler. They messed up and only installed 2 x 4GB sticks (I ordered 16GB), and it doesn't look like there is room under the coolers' fan to install another stick into that slot. Has anyone had trouble with this cooler covering the RAM slots?
I am going to send it back for them to take the cooler off and install, but I am concerned about the fan touching the ram, making noise etc, because even if it will fit, it looks like there will be no clearance.
Full Spec's Below
ANTEC, Performance One P183 V3 Black Mid-Tower Case, ATX,
CORSAIR, TX650 V2 Power Supply 650W, 80 PLUS® Bronze, 24-pin 0
ASUS, P8Z68-V PRO, LGA1155, Intel® Z68, DDR3-2200 (O.C.)
INTEL, Core™ i7-2600K Quad-Core 3.4GHz, HD Graphics 3000, LGA1155,
SCYTHE, Mugen 3 (SCMG-3000) CPU Cooler, Socket 1155/1156/1366/AM3/AM2,
ARCTIC SILVER, Arctic Silver 5 Thermal Compound, Polysynthetic Silver
KINGSTON, 8GB (2 x 4GB) HyperX Blu PC3-10600 DDR3 1333MHz CL9 1.5V SDRAM DIMM, Non-ECC 2
INTEL, 120GB 510 Series SSD, MLC, 450/210 MB/s, 2.5-Inch, SATA 6 Gb/s,
WESTERN DIGITAL, 2TB WD Caviar® Black™ (WD2002FAEX), SATA 6 Gb/s, 7200 RPM, 64MB Cache
SONY, AD-7261S Black 24x DVD±R/RW Dual-Layer Burner w/ Lightscribe, SATA,
KOUTECH, RCM630 All-in-One Card Reader, 3.5" Bay, USB 3.0 /2
Full Spec's Below
