I have installed 8GB ram But it is only showing 2.96 GB usable >.>> I dont know why can somebody tell me?
if the bios is showing the right amount and cpu-z can read the dimms right and report that there 4g each then the issue is with your os. a 32bit os stops at 3g of usable ram. if you want to use the full amount of ram you have to use a 64 bit os.
